ONTAP EMS reference
diskown.shareddsk events
diskown.sharedDsk.nonHACfg
Severity
ERROR
This message occurs when a disk is shared by multiple nodes in a non-HA or stand-alone configuration. If the procedure to convert an HA configuration to a non-HA configuration is not followed properly, the system may end up either having disks whose partitions are owned by another node, or owning partitions on non-local disks.
Corrective Action
Refer to the High-Availability Configuration Guide.
Syslog Message
Either some local disks have partitions that are not owned by the local node, or the local node owns partitions on non-local disks.
(None).
