mcc.so events
Creating your file...
Your file is ready
mcc.so.nodeObjectLmt.chkFail
- Severity
ALERT
- Description
This message occurs when a MetroCluster(tm) switchover operation cannot be performed on this node because it is in the takeover state and one of the nodes in its disaster recovery(DR) group has the "node-object-limit" MetroCluster configuration option set to off.
- Corrective Action
Use the "storage failover giveback" command to take this node out of takeover state.
- Syslog Message
Switchover operation cannot be performed on this node because it is in the takeover state and one of the nodes in its DR group has the "node-object-limit" MetroCluster configuration option set to off.
- Parameters
(None).
