ONTAP EMS reference
mcc.so events
mcc.so.nodeObjectLmt.chkFail
Severity
ALERT
This message occurs when a MetroCluster(tm) switchover operation cannot be performed on this node because it is in the takeover state and one of the nodes in its disaster recovery(DR) group has the "node-object-limit" MetroCluster configuration option set to off.
Corrective Action
Use the "storage failover giveback" command to take this node out of takeover state.
Syslog Message
Switchover operation cannot be performed on this node because it is in the takeover state and one of the nodes in its DR group has the "node-object-limit" MetroCluster configuration option set to off.
(None).
