san.mccpurgeverifyfailed events
Creating your file...
Your file is ready
san.MCCPurgeVerifyFailed
- Severity
ERROR
- Description
This message occurs in MetroCluster™ configurations on clustered Data ONTAP® systems when a SAN cache purge verify operation fails. The corresponding Vservers are not available to take part in the subsequent switchover or switchback operation until the purge verify operation succeeds.
- Corrective Action
Contact NetApp technical support for assistance in purging the SAN cache.
- Syslog Message
The following Vservers: %s failed in the SAN cache purge verify operation. Contact NetApp technical support for assistance in purging the SAN cache.
- Parameters
vserver (STRING): List of Vservers that failed the purge verify operation.
