ONTAP EMS reference
san.mccpurgeverifyfailed events
san.mccpurgeverifyfailed EMS events occur in MetroCluster™ configurations on clustered Data ONTAP® systems when a SAN cache purge verify operation fails.
san.MCCPurgeVerifyFailed
Severity
ERROR
This message occurs in MetroCluster™ configurations on clustered Data ONTAP® systems when a SAN cache purge verify operation fails. The corresponding Vservers are not available to take part in the subsequent switchover or switchback operation until the purge verify operation succeeds.
Corrective Action
Contact NetApp technical support for assistance in purging the SAN cache.
Syslog Message
The following Vservers: %s failed in the SAN cache purge verify operation. Contact NetApp technical support for assistance in purging the SAN cache.
vserver (STRING): List of Vservers that failed the purge verify operation.
