vldb.vldbaggr events
vldb.vldbAggr.missing
- Severity
ERROR
 - Description
This message occurs when an aggregate is identified that does not exist in the Volume Location Database. This could happen if a disk shelf that constitutes an aggregate is plugged in or when an aggregate is created in Maintenance mode.
 - Corrective Action
If this is a new aggregate that must be added to the Volume Location Database, then use the (privilege: diag) "debug vreport" command to resolve the inconsistency in the VLDB: 1. Run "debug vreport show" to show the object name. 2. Run "debug vreport fix -type aggregate -object object-name". If this is a stale aggregate that must be removed, then contact support personnel.
 - Syslog Message
The aggregate "%s" with UUID "%s" on node "%s" does not exist in the Volume Location Database.
 - Parameters
aggregate (STRING): Name of the aggregate.
uuid (STRING): Universally Unique Identifier (UUID) of the aggregate.
node (STRING): Name of the node.
