ONTAP EMS reference
vldb.vldbaggr events
vldb.vldbaggr EMS events occur when an aggregate is identified that does not exist in the Volume Location Database.
vldb.vldbAggr.missing
Severity
ERROR
This message occurs when an aggregate is identified that does not exist in the Volume Location Database. This could happen if a disk shelf that constitutes an aggregate is plugged in or when an aggregate is created in Maintenance mode.
Corrective Action
If this is a new aggregate that must be added to the Volume Location Database, then use the (privilege: diag) "debug vreport" command to resolve the inconsistency in the VLDB: 1. Run "debug vreport show" to show the object name. 2. Run "debug vreport fix -type aggregate -object object-name". If this is a stale aggregate that must be removed, then contact support personnel.
Syslog Message
The aggregate "%s" with UUID "%s" on node "%s" does not exist in the Volume Location Database.
aggregate (STRING): Name of the aggregate.
uuid (STRING): Universally Unique Identifier (UUID) of the aggregate.
node (STRING): Name of the node.
