vserver.peering events
vserver.peering.relCreated
- Severity
NOTICE
 - Description
This message occurs when the Vserver peer relationship is established.
 - Corrective Action
(None).
 - Syslog Message
Vserver peer relationship between %s and %s is established having remote peer Vserver name %s.
 - Parameters
vserver (STRING): Name of the Vserver for which a peer is created.
peer_vserver_localname (STRING): Name locally used for the peer Vserver created.
peer_vserver_remotename (STRING): Actual name of the peer Vserver.
vserver.peering.relDeleted
- Severity
INFORMATIONAL
 - Description
This message occurs when the Vserver peer relationship is deleted successfully.
 - Corrective Action
(None).
 - Syslog Message
"Vserver peer relationship between %s and %s is deleted."
 - Parameters
vserver (STRING): Name of the Vserver.
peer_vserver (STRING): Name of the peer Vserver.
vserver.peering.relResumed
- Severity
INFORMATIONAL
 - Description
This message occurs when the Vserver peer relationship is resumed successfully.
 - Corrective Action
(None).
 - Syslog Message
"Vserver peer relationship between %s and %s is resumed."
 - Parameters
vserver.peering.relSuspended
- Severity
INFORMATIONAL
 - Description
This message occurs when the Vserver peer relationship is suspended successfully.
 - Corrective Action
(None).
 - Syslog Message
"Vserver peer relationship between %s and %s is suspended."
 - Parameters
vserver.peering.remCallFailed
- Severity
ERROR
 - Description
This message occurs when any Vserver peering command fails because of a communication failure with a remote system.
 - Corrective Action
Use the "network interface show" command to verify that intercluster logical interfaces (LIFs) on both clusters are up. Use the "cluster peer health show -bypass-cache true" command to verify that cluster peering is healthy. If you want to retry a failed delete, suspend, or resume operation, consider using the "force" option, which bypasses network connectivity issues.
 - Syslog Message
"Vserver peering command '%s' failed. Reason: %s. Vserver peering states might be inconsistent."
 - Parameters
command (STRING): Vserver peering command.
reason (STRING): Reason for failure.
