vserver.peering events
vserver.peering EMS events occur when ONTAP encounters issues associated with Vserver peer relationship operations.
vserver.peering.relCreated
- Severity
NOTICE
- Description
This message occurs when the Vserver peer relationship is established.
- Corrective Action
(None).
- Syslog Message
Vserver peer relationship between %s and %s is established having remote peer Vserver name %s.
- Parameters
vserver (STRING): Name of the Vserver for which a peer is created.
peer_vserver_localname (STRING): Name locally used for the peer Vserver created.
peer_vserver_remotename (STRING): Actual name of the peer Vserver.
vserver.peering.relDeleted
- Severity
INFORMATIONAL
- Description
This message occurs when the Vserver peer relationship is deleted successfully.
- Corrective Action
(None).
- Syslog Message
"Vserver peer relationship between %s and %s is deleted."
- Parameters
vserver (STRING): Name of the Vserver.
peer_vserver (STRING): Name of the peer Vserver.
vserver.peering.relRenamed
- Severity
NOTICE
- Description
This message occurs when the storage virtual machine (SVM) peer relationship is modified.
- Corrective Action
(None).
- Syslog Message
The SVM peer relationship between local SVM "%s" (UUID "%s") and peer SVM "%s" (UUID "%s") is modified. The peer cluster changed from "%s" (ID "%s") to "%s" (ID "%s").
- Parameters
local_vserver_name (STRING): Local SVM name.
local_vserver_uuid (STRING): Local SVM universally unique identifier (UUID).
peer_vserver_name (STRING): Peer SVM name.
peer_vserver_uuid (STRING): Peer SVM UUID.
old_peer_cluster_name (STRING): Old peer cluster name.
old_peer_cluster_id (STRING): Old peer cluster ID.
new_peer_cluster_name (STRING): New peer cluster name.
new_peer_cluster_id (STRING): New peer cluster ID.
vserver.peering.relResumed
- Severity
INFORMATIONAL
- Description
This message occurs when the Vserver peer relationship is resumed successfully.
- Corrective Action
(None).
- Syslog Message
"Vserver peer relationship between %s and %s is resumed."
- Parameters
vserver.peering.relSuspended
- Severity
INFORMATIONAL
- Description
This message occurs when the Vserver peer relationship is suspended successfully.
- Corrective Action
(None).
- Syslog Message
"Vserver peer relationship between %s and %s is suspended."
- Parameters
vserver.peering.remCallFailed
- Severity
ERROR
- Description
This message occurs when any Vserver peering command fails because of a communication failure with a remote system.
- Corrective Action
Use the "network interface show" command to verify that intercluster logical interfaces (LIFs) on both clusters are up. Use the "cluster peer health show -bypass-cache true" command to verify that cluster peering is healthy. If you want to retry a failed delete, suspend, or resume operation, consider using the "force" option, which bypasses network connectivity issues.
- Syslog Message
"Vserver peering command '%s' failed. Reason: %s. Vserver peering states might be inconsistent."
- Parameters
command (STRING): Vserver peering command.
reason (STRING): Reason for failure.
