ONTAP EMS reference
vserver.peering events
vserver.peering.relCreated
Severity
NOTICE
This message occurs when the Vserver peer relationship is established.
Corrective Action
(None).
Syslog Message
Vserver peer relationship between %s and %s is established having remote peer Vserver name %s.
vserver (STRING): Name of the Vserver for which a peer is created.
peer_vserver_localname (STRING): Name locally used for the peer Vserver created.
peer_vserver_remotename (STRING): Actual name of the peer Vserver.
vserver.peering.relDeleted
Severity
INFORMATIONAL
This message occurs when the Vserver peer relationship is deleted successfully.
Corrective Action
(None).
Syslog Message
"Vserver peer relationship between %s and %s is deleted."
vserver (STRING): Name of the Vserver.
peer_vserver (STRING): Name of the peer Vserver.
vserver.peering.relRenamed
Severity
NOTICE
This message occurs when the storage virtual machine (SVM) peer relationship is modified.
Corrective Action
(None).
Syslog Message
The SVM peer relationship between local SVM "%s" (UUID "%s") and peer SVM "%s" (UUID "%s") is modified. The peer cluster changed from "%s" (ID "%s") to "%s" (ID "%s").
local_vserver_name (STRING): Local SVM name.
local_vserver_uuid (STRING): Local SVM universally unique identifier (UUID).
peer_vserver_name (STRING): Peer SVM name.
peer_vserver_uuid (STRING): Peer SVM UUID.
old_peer_cluster_name (STRING): Old peer cluster name.
old_peer_cluster_id (STRING): Old peer cluster ID.
new_peer_cluster_name (STRING): New peer cluster name.
new_peer_cluster_id (STRING): New peer cluster ID.
vserver.peering.relResumed
Severity
INFORMATIONAL
This message occurs when the Vserver peer relationship is resumed successfully.
Corrective Action
(None).
Syslog Message
"Vserver peer relationship between %s and %s is resumed."
vserver.peering.relSuspended
Severity
INFORMATIONAL
This message occurs when the Vserver peer relationship is suspended successfully.
Corrective Action
(None).
Syslog Message
"Vserver peer relationship between %s and %s is suspended."
vserver.peering.remCallFailed
Severity
ERROR
This message occurs when any Vserver peering command fails because of a communication failure with a remote system.
Corrective Action
Use the "network interface show" command to verify that intercluster logical interfaces (LIFs) on both clusters are up. Use the "cluster peer health show -bypass-cache true" command to verify that cluster peering is healthy. If you want to retry a failed delete, suspend, or resume operation, consider using the "force" option, which bypasses network connectivity issues.
Syslog Message
"Vserver peering command '%s' failed. Reason: %s. Vserver peering states might be inconsistent."
command (STRING): Vserver peering command.
reason (STRING): Reason for failure.
