dfu.clusterdisknotready events
dfu.clusterDiskNotReady
- Severity
ERROR
- Description
This message occurs when the controller failover partner reports that a disk selected for download is in the NOT READY state.
- Corrective Action
Only disks in the READY state can be downloaded to. If a disk is in the NOT READY state, it indicates that the disk has probably failed for some reason and should be returned for RMA.
- Syslog Message
Controller failover partner reports disk as NOT READY. Unable to download firmware to disk %s [%s %s %s] S/N [%s].
- Parameters
diskName (STRING): Name of the disk.
vendorName (STRING): Vendor name of the disk.
productId (STRING): Product ID of the disk.
fwVersion (STRING): Firmware version of the disk.
serialno (STRING): Serial number of the disk.
