ONTAP EMS reference
dfu.clusterdisknotready events
dfu.clusterdisknotready EMS events occur when the controller failover partner reports that a disk selected for download is in the NOT READY state.
dfu.clusterDiskNotReady
Severity
ERROR
This message occurs when the controller failover partner reports that a disk selected for download is in the NOT READY state.
Corrective Action
Only disks in the READY state can be downloaded to. If a disk is in the NOT READY state, it indicates that the disk has probably failed for some reason and should be returned for RMA.
Syslog Message
Controller failover partner reports disk as NOT READY. Unable to download firmware to disk %s [%s %s %s] S/N [%s].
diskName (STRING): Name of the disk.
vendorName (STRING): Vendor name of the disk.
productId (STRING): Product ID of the disk.
fwVersion (STRING): Firmware version of the disk.
serialno (STRING): Serial number of the disk.
