enc.operation events
enc.operation.aborted
- Severity
ERROR
 - Description
This message occurs when either the rekeying of an encrypted flexible volume, or the conversion of the volume from unencrypted to encrypted, has been aborted.
 - Corrective Action
Determine the cause of the error by using either the "volume encryption rekey show -vserver <vserver-name> -volume <volume-name>" command or the "volume encryption conversion show -vserver <vserver-name> -volume <volume-name>" command. Correct the error. If the error was related to rekeying, continue the operation by using the "volume encryption rekey resume -vserver <vserver-name> -volume <volume-name>" command. If the error was related to conversion to encryption, continue the operation by using the "volume encryption conversion resume -vserver <vserver-name> -volume <volume-name>" command.
 - Syslog Message
%s scan is aborted in the volume '%s' (aggr '%s'). Reason: %s.
 - Parameters
op (STRING): Rekey or conversion operation.
volume (STRING): Volume name.
aggr (STRING): Name of the containing aggregate.
status (STRING): Status of the scan.
enc.operation.completed
- Severity
NOTICE
 - Description
This message occurs when rekey or conversion to encryption operation is completed in a flexible volume.
 - Corrective Action
(None).
 - Syslog Message
%s operation is completed in the volume '%s' (aggr '%s').
 - Parameters
enc.operation.disableAid
- Severity
NOTICE
 - Description
This message occurs when the system automatically disables the Aggregate Inline Deduplication (AID) feature for a volume as it is converted from a non-encrypted volume to an encrypted volume because AID is not supported for an encrypted volume.
 - Corrective Action
(None).
 - Syslog Message
AID is disabled for volume %s within aggregate %s during conversion to encryption operation.
 - Parameters
enc.operation.failure
- Severity
ERROR
 - Description
This message occurs when there is a failure in encryption operation. The operation description explains the nature of operation and reason for failure.
 - Corrective Action
Ensure that there is enough space in the aggregate, cluster is healthy, volume location database is online, and then retry the volume encryption operation.
 - Syslog Message
Failure in %s operation on volume '%s' (aggr '%s'). Reason '%s'.
 - Parameters
desc (STRING): Describes the reason for the failure of operation with arguments.
enc.operation.started
- Severity
NOTICE
 - Description
This message occurs when rekey or conversion to encryption operation is started in a flexible volume.
 - Corrective Action
(None).
 - Syslog Message
%s operation is started in the volume '%s' (aggr '%s').
 - Parameters
