ONTAP EMS reference
enc.operation events
enc.operation EMS events occur when ONTAP encounters issues associated with volume encryption operations.
enc.operation.completed
Severity
NOTICE
This message occurs when rekey or conversion to encryption operation is completed in a flexible volume.
Corrective Action
(None).
Syslog Message
%s operation is completed in the volume '%s' (aggr '%s').
op (STRING): Rekey or conversion operation.
volume (STRING): Volume name.
aggr (STRING): Name of the containing aggregate.
enc.operation.disableAid
Severity
NOTICE
This message occurs when the system automatically disables the Aggregate Inline Deduplication (AID) feature for a volume as it is converted from a non-encrypted volume to an encrypted volume because AID is not supported for an encrypted volume.
Corrective Action
(None).
Syslog Message
AID is disabled for volume %s within aggregate %s during conversion to encryption operation.
enc.operation.failure
Severity
ERROR
This message occurs when there is a failure in encryption operation. The operation description explains the nature of operation and reason for failure.
Corrective Action
Ensure that there is enough space in the aggregate, cluster is healthy, volume location database is online, and then retry the volume encryption operation.
Syslog Message
Failure in %s operation on volume '%s' (aggr '%s'). Reason '%s'.
desc (STRING): Describes the reason for the failure of operation with arguments.
enc.operation.started
Severity
NOTICE
This message occurs when rekey or conversion to encryption operation is started in a flexible volume.
Corrective Action
(None).
Syslog Message
%s operation is started in the volume '%s' (aggr '%s').
