enc.operation events
enc.operation EMS events occur when ONTAP encounters issues associated with volume encryption operations.
enc.operation.aborted
- Severity
ERROR
- Description
This message occurs when either the rekeying of an encrypted flexible volume, or the conversion of the volume from unencrypted to encrypted, is aborted.
- Corrective Action
For ASA r2, contact NetApp technical support for assistance to resume the encryption operation. For all other systems, determine the cause of the error by using either the "volume encryption rekey show -vserver <vserver-name> -volume <volume-name>" command or the "volume encryption conversion show -vserver <vserver-name> -volume <volume-name>" command. Correct the error. If the error is related to rekeying, continue the operation by using the "volume encryption rekey resume -vserver <vserver-name> -volume <volume-name>" command. If the error is related to conversion to encryption, continue the operation by using the "volume encryption conversion resume -vserver <vserver-name> -volume <volume-name>" command.
- Syslog Message
%s scan is aborted in the volume "%s" (aggr "%s"). Reason: %s.
- Parameters
op (STRING): Rekey or conversion operation.
volume (STRING): Volume name.
aggr (STRING): Name of the containing aggregate.
status (STRING): Status of the scan.
enc.operation.completed
- Severity
NOTICE
- Description
This message occurs when rekey or conversion to encryption operation is completed in a flexible volume.
- Corrective Action
(None).
- Syslog Message
%s operation is completed in the volume '%s' (aggr '%s').
- Parameters
enc.operation.disableAid
- Severity
NOTICE
- Description
This message occurs when the system automatically disables the Aggregate Inline Deduplication (AID) feature for a volume as it is converted from a non-encrypted volume to an encrypted volume because AID is not supported for an encrypted volume.
- Corrective Action
(None).
- Syslog Message
AID is disabled for volume %s within aggregate %s during conversion to encryption operation.
- Parameters
enc.operation.failure
- Severity
ERROR
- Description
This message occurs when there is a failure in encryption operation. The operation description explains the nature of operation and reason for failure.
- Corrective Action
Ensure that there is enough space in the aggregate, cluster is healthy, volume location database is online, and then retry the volume encryption operation.
- Syslog Message
Failure in %s operation on volume '%s' (aggr '%s'). Reason '%s'.
- Parameters
desc (STRING): Describes the reason for the failure of operation with arguments.
enc.operation.started
- Severity
NOTICE
- Description
This message occurs when rekey or conversion to encryption operation is started in a flexible volume.
- Corrective Action
(None).
- Syslog Message
%s operation is started in the volume '%s' (aggr '%s').
- Parameters
