snapmirror.lrs events
snapmirror.lrs EMS events occur when SnapMirror encounters mismatched file types between two snapshots that it is comparing.
snapmirror.lrs.FiletypeMod
- Severity
ALERT
- Description
This message occurs when SnapMirror encounters mismatched file types between two Snapshot copies that it is comparing. The transfer is aborted and future attempts fail until the problem is resolved.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
SnapMirror encountered mismatched file types for inode %u in volume %u. It has file type %u in Snapshot copy %u and a file type %u in Snapshot copy %u.
- Parameters
inode_num (INT): Identifier of the affected file.
fsid (INT): FSID of the volume.
base_filetype (INT): File type of the file in the base Snapshot copy.
base_snap_id (INT): Identifier of the base Snapshot copy.
incr_filetype (INT): File type of the file in the incremental Snapshot copy.
incr_snap_id (INT): Identifier of the incremental Snapshot copy.
