snapmirror.lrs events
snapmirror.lrs EMS events occur when SnapMirror encounters mismatched file types between two snapshots that it is comparing.
snapmirror.lrs.FiletypeMod
- Severity
ALERT
- Description
This message occurs when SnapMirror encounters mismatched file types between two snapshots that it is comparing. The transfer is aborted and future attempts fail until the problem is resolved.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
SnapMirror encountered mismatched file types for inode %u in volume %u. It has file type %u in snapshot %u and a file type %u in snapshot %u.
- Parameters
inode_num (INT): Identifier of the affected file.
fsid (INT): FSID of the volume.
base_filetype (INT): File type of the file in the base snapshot.
base_snap_id (INT): Identifier of the base snapshot.
incr_filetype (INT): File type of the file in the incremental snapshot.
incr_snap_id (INT): Identifier of the incremental snapshot.
