ONTAP EMS reference
snapmirror.lrs events
snapmirror.lrs EMS events occur when SnapMirror encounters mismatched file types between two snapshots that it is comparing.
snapmirror.lrs.FiletypeMod
Severity
ALERT
This message occurs when SnapMirror encounters mismatched file types between two snapshots that it is comparing. The transfer is aborted and future attempts fail until the problem is resolved.
Corrective Action
Contact NetApp technical support.
Syslog Message
SnapMirror encountered mismatched file types for inode %u in volume %u. It has file type %u in snapshot %u and a file type %u in snapshot %u.
inode_num (INT): Identifier of the affected file.
fsid (INT): FSID of the volume.
base_filetype (INT): File type of the file in the base snapshot.
base_snap_id (INT): Identifier of the base snapshot.
incr_filetype (INT): File type of the file in the incremental snapshot.
incr_snap_id (INT): Identifier of the incremental snapshot.
