wafl.sm events
wafl.sm.vvol.read.failed
- Severity
ALERT
- Description
This message occurs when SnapMirror® fails to read a block from the container file of a FlexVol® SnapMirror source volume. This error typically means that there is some corruption in the FlexVol volume.
- Corrective Action
Contact NetApp technical support for assistance.
- Syslog Message
SnapMirror encountered an error while reading the block at VVBN %llu in volume '%s%s%s'.
- Parameters
vvbn (LONGINT): Virtual volume block number (VVBN) on which the read failed.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Uniquely identifies the volume, if the volume name itself is insufficient.
