ONTAP EMS reference
wafl.sm events
wafl.sm EMS events occur when SnapMirror® fails to read a block from the container file of a FlexVol® SnapMirror source volume.
wafl.sm.vvol.read.failed
Severity
ALERT
This message occurs when SnapMirror® fails to read a block from the container file of a FlexVol® SnapMirror source volume. This error typically means that there is some corruption in the FlexVol volume.
Corrective Action
Contact NetApp technical support for assistance.
Syslog Message
SnapMirror encountered an error while reading the block at VVBN %llu in volume '%s%s%s'.
vvbn (LONGINT): Virtual volume block number (VVBN) on which the read failed.
vol (STRING): Name of the volume.
app (STRING): Application UUID.
volident (STRING): Uniquely identifies the volume, if the volume name itself is insufficient.
