ONTAP EMS reference
diskown.assignexceeded events
diskown.assignexceeded EMS events occur when an attempt is made to assign more disks than are supported by this node.
diskown.AssignExceeded
Severity
ERROR
This message occurs when an attempt is made to assign more disks than are supported by this node.
Corrective Action
Review the system capacity limits and the assigned disks on this system.
Syslog Message
The maximum number of disks that can be assigned to this node has been exceeded. Attempted to assign %d, maximum supported: %d.
attempted (INT): Number of disks attempted to assign.
supported (INT): Number of disks supported.
