diskown.assignexceeded events
diskown.assignexceeded EMS events occur when an attempt is made to assign more disks than are supported by this node.
diskown.AssignExceeded
- Severity
ERROR
- Description
This message occurs when an attempt is made to assign more disks than are supported by this node.
- Corrective Action
Review the system capacity limits and the assigned disks on this system.
- Syslog Message
The maximum number of disks that can be assigned to this node has been exceeded. Attempted to assign %d, maximum supported: %d.
- Parameters
attempted (INT): Number of disks attempted to assign.
supported (INT): Number of disks supported.
