ONTAP EMS reference
ha.takeover events
ha.takeover.bypOptimChange
Severity
INFORMATIONAL
This message occurs when the value of the 'bypass-takeover-optimization' parameter of the "storage failover" command is changed on a node.
Corrective Action
(None).
Syslog Message
(None).
node_name (STRING): Name of the node.
new_value (STRING): New value of the 'bypass-takeover-optimization' parameter.
ha.takeover.checkEnd
Severity
ALERT
This message occurs when a node is simulating a takeover. This marks the end of a simulated takeover on the local node.
Corrective Action
(None).
Syslog Message
This node is testing the takeover workflow. This test is a simulation only. The simulation has ended on the local node.
(None).
ha.takeover.checkError
Severity
ALERT
This message occurs when a takeover with the check-only flag detects an error that would prevent takeover.
Corrective Action
Use the "storage failover check-takeover" command to identify the failures that occured along the takeover path. Perform corrective action based on error information shown by the command.
Syslog Message
This node is testing the takeover workflow. This test is a simulation only. The simulation has encountered and error that would disrupt takeover.
(None).
ha.takeover.checkStart
Severity
ALERT
This message occurs when a node is simulating a takeover. This marks the start of a simulated takeover on the local node.
Corrective Action
(None).
Syslog Message
This node is testing the takeover workflow. This test is a simulation only. The simulation has started on the local node.
(None).
ha.takeover.stateDuration
Severity
NOTICE
This message occurs when a node has been in the takeover state for a set time period of 1 hour and every hour thereafter the node continues to be in that state.
Corrective Action
(None).
Syslog Message
Node (%s) in takeover for %d days and %d hours.
host (STRING): Name of the host
days_in_TO (INT): Number of days in takeover
hours_in_TO (INT): Number of hours in takeover
