ha.takeover events
ha.takeover EMS events occur when ONTAP encounters issues associated with high-availability (HA) takeover operations.
ha.takeover.bypOptimChange
- Severity
INFORMATIONAL
- Description
This message occurs when the value of the 'bypass-takeover-optimization' parameter of the "storage failover" command is changed on a node.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
node_name (STRING): Name of the node.
new_value (STRING): New value of the 'bypass-takeover-optimization' parameter.
ha.takeover.checkEnd
- Severity
ALERT
- Description
This message occurs when a node is simulating a takeover. This marks the end of a simulated takeover on the local node.
- Corrective Action
(None).
- Syslog Message
This node is testing the takeover workflow. This test is a simulation only. The simulation has ended on the local node.
- Parameters
(None).
ha.takeover.checkError
- Severity
ALERT
- Description
This message occurs when a takeover with the check-only flag detects an error that would prevent takeover.
- Corrective Action
Use the "storage failover check-takeover" command to identify the failures that occurred along the takeover path. Perform corrective action based on error information shown by the command.
- Syslog Message
This node is simulating the takeover workflow and has encountered an error that would disrupt takeover.
- Parameters
(None).
ha.takeover.checkStart
- Severity
ALERT
- Description
This message occurs when a node is simulating a takeover. This marks the start of a simulated takeover on the local node.
- Corrective Action
(None).
- Syslog Message
This node is testing the takeover workflow. This test is a simulation only. The simulation has started on the local node.
- Parameters
(None).
ha.takeover.stateDuration
- Severity
NOTICE
- Description
This message occurs when a node has been in the takeover state for a set time period of 1 hour and every hour thereafter the node continues to be in that state.
- Corrective Action
(None).
- Syslog Message
Node (%s) in takeover for %d days and %d hours.
- Parameters
host (STRING): Name of the host
days_in_TO (INT): Number of days in takeover
hours_in_TO (INT): Number of hours in takeover
