ONTAP EMS reference
mgmtgwd.certificate events
mgmtgwd.certificate.expired
Severity
ERROR
This message occurs when a digital certificate for a Vserver expires. Client-server communication is not secure.
Corrective Action
Install a new digital certificate on the system using the 'security certificate create' or 'security certificate install' command.
Syslog Message
A digital certificate with Fully Qualified Domain Name (FQDN) %s, Serial Number %s, Certificate Authority '%s' and type %s for Vserver %s has expired.
common_name (STRING): Name of the Fully Qualified Domain Name(FQDN) whose digital certificate expired.
serial_number (STRING): Serial Number of the digital certificate.
certificate_authority (STRING): Name of the Certificate Authority.
type (STRING): Type of the digital certificate.
vserver (STRING): Name of the Vserver.
mgmtgwd.certificate.expiring
Severity
ERROR
This message occurs when a digital certificate for a Vserver is about to expire. Client-server communication will not be secure if the certificate expires.
Corrective Action
Syslog Message
A digital certificate with Fully Qualified Domain Name (FQDN) %s, Serial Number %s, Certificate Authority '%s' and type %s for Vserver %s will expire in the next %d day(s).
common_name (STRING): Name of the Fully Qualified Domain Name(FQDN) whose digital certificate is about to expire.
certificate_authority (STRING): Name of the Certificate Authority whose digital certificate is about to expire.
days (LONGINT): Number of days remaining until the certificate expires.
mgmtgwd.certificate.switch
Severity
ALERT
This message occurs when the user installed certificates of the service processor API service become invalid and are subsequently replaced with internal certificates.
Corrective Action
Install new digital certificates on the system using the "security certificate create" or "security certificate install" command and enable them using "system service-processor api-service enable-installed-certificates" command.
Syslog Message
User installed certificates of the service processor API service are replaced with internal certificates.
(None).
