mgmtgwd.certificate events
mgmtgwd.certificate EMS events occur when ONTAP encounters issues associated with digital certificate expiration for Vservers.
mgmtgwd.certificate.expired
- Severity
ERROR
- Description
This message occurs when a digital certificate for a Vserver expires. Client-server communication is not secure.
- Corrective Action
Install a new digital certificate on the system using the 'security certificate create' or 'security certificate install' command.
- Syslog Message
A digital certificate with Fully Qualified Domain Name (FQDN) %s, Serial Number %s, Certificate Authority '%s' and type %s for Vserver %s has expired.
- Parameters
common_name (STRING): Name of the Fully Qualified Domain Name(FQDN) whose digital certificate expired.
serial_number (STRING): Serial Number of the digital certificate.
certificate_authority (STRING): Name of the Certificate Authority.
type (STRING): Type of the digital certificate.
vserver (STRING): Name of the Vserver.
mgmtgwd.certificate.expiring
- Severity
ERROR
- Description
This message occurs when a digital certificate for a Vserver is about to expire. Client-server communication will not be secure if the certificate expires.
- Corrective Action
- Syslog Message
A digital certificate with Fully Qualified Domain Name (FQDN) %s, Serial Number %s, Certificate Authority '%s' and type %s for Vserver %s will expire in the next %d day(s).
- Parameters
common_name (STRING): Name of the Fully Qualified Domain Name(FQDN) whose digital certificate is about to expire.
certificate_authority (STRING): Name of the Certificate Authority whose digital certificate is about to expire.
days (LONGINT): Number of days remaining until the certificate expires.
mgmtgwd.certificate.switch
- Severity
ALERT
- Description
This message occurs when the user installed certificates of the service processor API service become invalid and are subsequently replaced with internal certificates.
- Corrective Action
Install new digital certificates on the system using the "security certificate create" or "security certificate install" command and enable them using "system service-processor api-service enable-installed-certificates" command.
- Syslog Message
User installed certificates of the service processor API service are replaced with internal certificates.
- Parameters
(None).
