repl.src events
repl.src EMS events occur when SnapMirror® logical transfer is not possible due to incompatible snapshots.
repl.src.snaps.check.failed
- Severity
ERROR
- Description
This message occurs when SnapMirror® logical transfer is not possible due to incompatible snapshots.
- Corrective Action
Create new snapshot on the source volume and use that for Logical transfer.
- Syslog Message
SnapMirror operation failed because the reference and/or the transfer snapshots on the source volume are either a) from a release prior to Data ONTAP 8.2 b) captured in a nonclustered format c) not upgraded to dual inode space. These snapshots cannot be used for logical transfer.
- Parameters
srcVolMsid (LONGINT): Source volume Master Data Set ID (MSID).
srcVolDsid (LONGINT): Source volume Data Set ID (DSID).
srcVolVserverId (INT): Source volume Vserver ID.
srcInstanceImageUuid (STRING): Source transfer instance snapshot UUID.
srcVersionImageUuid (STRING): Source transfer version snapshot UUID.
srcInstanceRefImageUuid (STRING): Source reference instance snapshot UUID.
srcVersionRefImageUuid (STRING): Source reference version snapshot UUID.
