repl.src events
repl.src.snaps.check.failed
- Severity
ERROR
 - Description
This message occurs when SnapMirror® logical transfer is not possible due to incompatible Snapshot copies.
 - Corrective Action
Create new Snapshot copy on the source volume and use that for Logical transfer.
 - Syslog Message
SnapMirror operation failed because the reference and/or the transfer Snapshot copies on the source volume are either a) from a release prior to Data ONTAP 8.2 b) captured in a nonclustered format c) not upgraded to dual inode space. These Snapshot copies cannot be used for logical transfer.
 - Parameters
srcVolMsid (LONGINT): Source volume Master Data Set ID (MSID).
srcVolDsid (LONGINT): Source volume Data Set ID (DSID).
srcVolVserverId (INT): Source volume Vserver ID.
srcInstanceImageUuid (STRING): Source transfer instance Snapshot copy UUID.
srcVersionImageUuid (STRING): Source transfer version Snapshot copy UUID.
srcInstanceRefImageUuid (STRING): Source reference instance Snapshot copy UUID.
srcVersionRefImageUuid (STRING): Source reference version Snapshot copy UUID.
