sm.xfer events
sm.xfer.fail.del.snap
- Severity
ERROR
 - Description
This message occurs when deletion of a snapshot on the destination volume fails, and therefore a subsequent transfer exceeds the maximum supported snapshot count for the vault destination.
 - Corrective Action
Manually delete the snapshots from the destination volume and reissue the failed SnapMirror command.
 - Syslog Message
Unable to delete snapshot '%s' from destination volume '%s' of the relationship with relationship UUID '%s' to make space for for newer snapshots.
 - Parameters
snap_name (STRING): Snapshot that was not deleted.
dst_path (STRING): Destination volume of the relationship.
relationship_id (STRING): UUID of the snapmirror relationship.
sm.xfer.fail.maxlim.snap
- Severity
ALERT
 - Description
This message occurs when a SnapMirror® transfer fails because the maximum supported snapshot limit for a SnapMirror destination is reached and there is no space for a new, incoming snapshot.
 - Corrective Action
Reduce the "keep" count by using the "snapmirror policy modify-rule -policy [policy_name] -keep [keep_count]" command, or by manually deleting snapshots from the SnapMirror® destination.
 - Syslog Message
The number of snapshots on destination volume '%s' of the relationship with relationship UUID '%s' and policy '%s' has reached the maximum supported.
 - Parameters
policy_name (STRING): SnapMirror policy name.
sm.xfer.incr.snap.rename
- Severity
ERROR
 - Description
This message occurs when an incomplete SnapMirror® operation is detected for an incremental snapshot that no longer exists on the SnapMirror® source volume. As a result, SnapMirror creates a snapshot with the name "snapmirror_vlt_xfer_recovery" and requires a SnapMirror Resync operation to be performed on the SnapVault relationship to resume data protection.
 - Corrective Action
Resume data protection either by retaining or deleting the snapshot Use the 'snapmirror resync -preserve' to retain it or use the 'snapmirror resync' command to delete it.
 - Syslog Message
An incomplete SnapMirror operation was detected for an incremental snapshot that no longer exists on the source volume '%s'. The data transfer for the incremental snapshot was completed but the snapshot on the vault destination '%s' was not created. Instead, a snapshot with the name "snapmirror_vlt_xfer_recovery" was created.
 - Parameters
src_path (STRING): Source volume of the relationship.
sm.xfer.no.new.snap
- Severity
INFORMATIONAL
 - Description
This message occurs when a SnapMirror® update does not find any new snapshots to transfer. This can happen when none of the newer snapshots on the source has a SnapMirror® label that matches a SnapMirror policy.
 - Corrective Action
Check that the SnapMirror label from the snapshot policy matches SnapMirror policy rules.
 - Syslog Message
SnapMirror update did not find any new snapshots to transfer from the source volume '%s' of the relationship with relationship UUID '%s'.
 - Parameters
src_path (STRING): Source volume of the SnapMirror relationship.
sm.xfer.same.name.snap.dst
- Severity
ERROR
 - Description
This message occurs when a snapshot was not transferred from the source volume to the destination volume during a snapmirror transfer because a snapshot with the same name already exists in the destination volume.
 - Corrective Action
Rename the snapshot in the source volume to a name that does not match the name of any snapshot in the destination volume. Then, wait for the next scheduled update or trigger a manual snapmirror update.
 - Syslog Message
Snapshot "%s" was not transferred from the source volume "%s" to the destination volume "%s" because the destination volume has a snapshot with the same name.
 - Parameters
snap_name (STRING): Name of the snapshot that was not transferred.
sm.xfer.warn.limit
- Severity
ERROR
 - Description
This message occurs when a SnapMirror® transfer receives a warning when it is approaching the "keep" count of a particular SnapMirror® relationship.
 - Corrective Action
Increase the "keep" count to transfer more snapshots with the same label using the following command: snapmirror policy modify-rule -policy [policy_name] -keep [keep_count]
 - Syslog Message
Warnings issued for SnapMirror relationship with source volume '%s' and destination volume '%s' with relationship UUID '%s' : %s
 - Parameters
warn_str (STRING): SnapMirror transfer warning.
sm.xfer.warn.snapshot.count.limit
- Severity
ERROR
 - Description
This message occurs during a SnapMirror® transfer, when the snapshot count limit is reached for the SnapMirror relationship between the indicated source and destination volumes.
 - Corrective Action
Delete some snapshots from the destination volume to create space for new snapshots to be transferred to it.
 - Syslog Message
Snapshot count limit for SnapMirror relationship with source volume '%s' and destination volume '%s' with relationship UUID '%s' has been reached : %s
 - Parameters
dst_path (STRING): Destination volume of the SnapMirror relationship.
