bsdsocket.queuelimit events
bsdsocket.queuelimit EMS events occur when the number of connection requests for a socket reaches the maximum number.
bsdsocket.queueLimit.reached
- Severity
ERROR
- Description
This message occurs when the number of connection requests for a socket reaches the maximum number. These connection requests include partially completed connections and connections that are ready to be accepted. Network misconfigurations can cause ONTAP servers to slow down on a given TCP port and can be the cause of this message. This event can also be caused by a denial-of-service attack or an overloaded system.
- Corrective Action
Try turning off and back on the LIF on which the last connection was received. If the issue remains after correcting any network misconfigurations, contact NetApp technical support.
- Syslog Message
Number of connection requests for the socket bound to port %d having the IP address %s has reached the limit of %d connections. The last connection was received on IP address %s. The socket uses %s protocol. This event has occurred %llu times since the last warning.
- Parameters
port (INT): Local port bound to the socket.
ipAddress (STRING): IP address of the socket.
limit (INT): Maximum number of connection requests per socket.
childRecvIpAddress (STRING): IP address on which the last connection request was received.
protocol (STRING): Protocol used by the socket.
count (LONGINT): Number of occurrences for this event since the last warning.
