ONTAP EMS reference
config.atanotsupported events
config.atanotsupported EMS events occur when an ATA disk is found, but the appliance does not support it.
config.ATAnotSupported
Severity
ERROR
This message occurs when an ATA disk is found, but the appliance does not support it.
Corrective Action
Remove the ATA disks or upgrade your appliance to a model that supports ATA disks. Check your support provider's web site or knowledgebase for more information about appliance models that support ATA disks.
Syslog Message
ATA disks are not supported on this appliance. Disk %s is an ATA disk and should be removed.
disk (STRING): Name of the disk.
