netif.nicnotsupported events
netif.nicnotsupported EMS events occur when the installed network interface card (NIC) version is not supported.
netif.nicNotSupported
- Severity
ERROR
- Description
This message occurs when the installed network interface card (NIC) version is not supported.
- Corrective Action
Replace the NIC with one purchased from NetApp.
- Syslog Message
The NIC in slot %d is not supported. The %s is not supported.
- Parameters
slot (INT): Slot number of the NIC.
reason (STRING): Specific reason the NIC is not supported.
