ONTAP EMS reference
netif.nicnotsupported events
netif.nicnotsupported EMS events occur when the installed network interface card (NIC) version is not supported.
netif.nicNotSupported
Severity
ERROR
This message occurs when the installed network interface card (NIC) version is not supported.
Corrective Action
Replace the NIC with one purchased from NetApp.
Syslog Message
The NIC in slot %d is not supported. The %s is not supported.
slot (INT): Slot number of the NIC.
reason (STRING): Specific reason the NIC is not supported.
