ONTAP EMS reference
pha.dev events
pha.dev EMS events occur when ONTAP encounters issues associated with passthrough host adapter (PHA) device operations.
pha.dev.get.capacity.failed
Severity
ERROR
This message occurs when ONTAP®software fails to get a drives's capacity after an extended wait. As a result, cannot add the drive.
Corrective Action
Ensure that the hypervisor's device is still connected and accessible by ONTAP.
Syslog Message
Failed to get drive capacity for device %s%d after %d seconds.
devname (STRING): Name of the device.
unit (INT): Unit number of the device.
wait_time (INT): Number of seconds waited for capacity information.
pha.dev.get.uuid.bioReadErr
Severity
ERROR
This message occurs when block read operation for the passthrough host adapter (PHA) disk header returns an error. As a result, Data ONTAP® is unable to add or manage this device.
Corrective Action
Ensure that the device is still connected to and accessible by Data ONTAP® and retry the operation.
Syslog Message
Failed to get UUID for device %s%d. Reason: Block read operation returned an error: 0x%x.
bio_error (INTHEX): Error code returned by block read operation.
pha.dev.get.uuid.devNotAdded
Severity
ERROR
This message occurs when Data ONTAP® fails to get disk header after multiple retries and finally give up. As a result, Data ONTAP® is unable to add the disk.
Corrective Action
Syslog Message
Failed to get disk header for device %s%d. Number of bioerr %d Retries %d.
bioerr_cnt (INT): Number of BIO errors.
retry_cnt (INT): Number of retries.
pha.dev.get.uuid.devNotExist
Severity
ERROR
This message occurs when Data ONTAP® fails to retrieve the the descriptor for the passthrough host adapter (PHA) device. As a result, Data ONTAP® fails to read the header on this device and is unable to add or manage it.
Corrective Action
Syslog Message
Failed to retrieve the descriptor for device %s%d. Reason: %s.
error (STRING): Error message.
pha.dev.header.err
Severity
ERROR
This message occurs when a disk header operation encounters a device error. As a result, ONTAP® might be unable to add or manage this device.
Corrective Action
Ensure that the device is still connected to and accessible by ONTAP. If the device is reported as healthy by the hypervisor, contact NetApp technical support to open a support case to investigate the underlying cause.
Syslog Message
Functional operation "%s" failed for device %s%d. Error number: 0x%x, CAM status: 0x%x, SCSI (status: 0x%x, sense key: x%x, sense code: 0x%x, additional sense code: 0x%x, additional sense code qualifier: 0x%x).
operation (STRING): Name of the functional operation.
bio_error (INTHEX): Error code returned by the device.
cam_status (INTHEX): Common Access Method (CAM) status code returned by the device.
scsi_status (INTHEX): SCSI status code returned by the device, if available.
error_code (INTHEX): SCSI error code returned by the device, if available.
sense_key (INTHEX): SCSI sense key returned by the device, if available.
asc (INTHEX): SCSI additional sense code returned by the device, if available.
ascq (INTHEX): SCSI additional sense code qualifier returned by the device, if available.
pha.dev.uuidWriteHeaderErr
Severity
ERROR
This message occurs when Data ONTAP® fails to write the header to the passthrough host adapter (PHA) device. As a result, Data ONTAP® is unable to add or manage this device.
Corrective Action
Syslog Message
Failed to write header to the device %s%d.
