smtape.rst events
smtape.rst EMS events occur when ONTAP encounters issues associated with SMTape restore operations.
smtape.rst.abort.chksum.err
- Severity
ERROR
- Description
This message occurs when an SMTape restore operation from tape is aborted due to checksum error.
- Corrective Action
Make sure that the correct tape is loaded and the tape is positioned correctly. If the tape is corrupted, contact NetApp technical support for the best effort recovery mechanisms.
- Syslog Message
SMTape restore session %d to %s from %s was aborted due to checksum error.
- Parameters
sessionid (INT): Session ID of the SMTape operation.
dstvolpath (STRING): SMTape destination volume.
tapepath (STRING): Current source device from which restore was performed.
smtape.rst.abort.read.err
- Severity
ERROR
- Description
This messages occurs when an SMTape restore operation is aborted because a read from the tape device fails.
- Corrective Action
Make sure that the input tape device and media are readable. Check for error details in the log file at /mroot/etc/log/backup.
- Syslog Message
SMTape restore session %d to %s from %s was aborted because read from input failed.
- Parameters
smtape.rst.fail
- Severity
ERROR
- Description
This message occurs when an SMTape restore operation fails.
- Corrective Action
Check for error details in the log file at /mroot/etc/log/backup. Retry the command after resolving the error reported.
- Syslog Message
SMTape restore session %d to %s from %s failed with error %s.
- Parameters
errorstring (STRING): Error string returned by SMTape.
smtape.rst.success
- Severity
NOTICE
- Description
This message occurs when an SMTape restore operation from tape succeeds.
- Corrective Action
(None).
- Syslog Message
SMTape restore session %d from tape to %s was successful. %s.
- Parameters
stats (STRING): Statistics for the SMTape restore.
smtape.rst.tape.change
- Severity
NOTICE
- Description
This message occurs when a CLI-based SMTape restore operation from tape reaches end of tape.
- Corrective Action
Load the next tape media onto a drive and position it correctly, and then issue the 'system smtape continue -session-id [session-id] -tape [tapepath]' command with the new tape path.
- Syslog Message
SMTape restore session %d from %s to %s is waiting for a tape change.
- Parameters
tapepath (STRING): Current source tape device from which restore was performed.
