fcvi.cross events
fcvi.cross EMS events occur when the fcvi driver detects a cross connection.
fcvi.cross.connect.detected
- Severity
ERROR
- Description
This message occurs when the fcvi driver detects a cross connection
- Corrective Action
Check the FCVI interconnect cabling at the local and remote nodes. FCVI adapter ports fcvi_device_0s and fcvi_device_1s should not be connected to the same fabric. Contact NetApp technical support if the problem persists.
- Syslog Message
FC-VI adapter: Cross Connection detected between local port %s and remote port %s. Local System ID = %llu, Remote System ID = %llu.
- Parameters
lname (STRING): Local node's port name.
rname (STRING): Remote node's port name.
lsid (LONGINT): Local node's system id.
rsid (LONGINT): Remote node's system id.
