mgmt.cifssymlink events
mgmt.cifssymlink EMS events occur when ONTAP encounters issues associated with CIFS symbolic link configuration.
mgmt.cifssymlink.failure
- Severity
ERROR
- Description
This message occurs when configuration of a CIFS symbolic link fails; the symbolic link might not be available through CIFS.
- Corrective Action
Check the reason for the error and take action accordingly.
- Syslog Message
Failed to configure CIFS symlink. Error: %s.
- Parameters
reason (STRING): Reason for the failure.
vservername (STRING): Name of the vserver.
unix_path (STRING): The UNIX path.
mgmt.cifssymlink.success
- Severity
INFORMATIONAL
- Description
This message occurs when a CIFS symbolic link is successfully configured after a failure.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
