ONTAP EMS reference
monitor.iocard events
monitor.iocard EMS events occur when ONTAP encounters issues associated with I/O card operation.
monitor.ioCard.degraded
Severity
ALERT
This message indicates that an I/O card is degraded.
Corrective Action
Exchange or replace the card with a known good card in the same I/O slot. If the problem persists, contact NetApp technical support for replacement assistance.
Syslog Message
IO card is degraded: %s
reasonText (STRING): Slot number of the card and the reason the card is degraded.
monitor.ioCard.ok
Severity
NOTICE
This message indicates that an I/O card is operating properly.
Corrective Action
None.
Syslog Message
IO card on slot %d is OK
slot_number (INT): Slot number of the card.
monitor.ioCard.sfp.noTemp
Severity
ERROR
This message occurs when an optical transceiver or cable connected to the I/O module does not report an internal temperature reading. The transceiver or cable might not include a temperature sensor or the sensor is not currently readable. The system's environmental policy will not be able to regulate cooling for this hardware component via system fan speed changes.
Corrective Action
If possible, exchange or replace the transceiver with one that includes a temperature sensor.
Syslog Message
Optical transceiver or cable does not support an internal temperature sensor. Sensor: %s.
sensor (STRING): Sensor ID of the optical transceiver.
monitor.ioCard.temp.timeout
Severity
ERROR
This message occurs when a timeout occurs while reading the temperature of an I/O card. I/O card temperature-based policies are temporarily disabled. Normal operation will resume once the reading of I/O card temperatures is successful.
Corrective Action
Contact NetApp technical support.
Syslog Message
Timeout while reading temperature of I/O card in slot %d.
slot (INT): Slot Number of the I/O card.
