nvmens.smbc events
nvmens.smbc EMS events occur when an NVMe namespace is partially restored to a SnapMirror® active sync volume because the SnapMirror® active sync volume does not support NVMe namespace.
NVMeNS.SMBC.vol.unsupp
- Severity
ERROR
- Description
This message occurs when an NVMe namespace is partially restored to a SnapMirror® active sync volume because the SnapMirror® active sync volume does not support NVMe namespace.
- Corrective Action
Restore of NVMe namespace to the SnapMirror® active sync volume is not supported although it is partially created on the SnapMirror® active sync volume as part of restore. The NVMe namespace needs to be manually deleted. Contact NetApp technical support for assistance.
- Syslog Message
NVMe namespace "%s" is not supported on SnapMirror® active sync volume "%s" (DSID %llu).
- Parameters
path (STRING): Path for the NVMe namespace that has been restored.
volume_name (STRING): Name of the containing volume.
volume_dsid (LONGINT): Dataset ID (DSID) of the containing volume.
