Planning summary for ONTAP systems using array LUNs
When you plan to use array LUNs with ONTAP systems, you must communicate with the storage array and switch administrators so that the back-end devices are configured to work with ONTAP systems.
The following table summarizes the major planning tasks and the location of information to help you with each task.
Planning task | Where to find information |
Determining requirements for setting up your storage array to work with ONTAP |
Guidelines for array LUN use with ONTAP |
Determining ONTAP limits regarding array LUNs |
Determining a LUN security scheme, setting access controls on the storage array and, if switches are deployed, setting zoning on switches |
Determining a port-to-port connectivity scheme between the ONTAP systems and the storage array |
Determining which ONTAP system is to “own” which array LUN (disk ownership) |
