ONTAP Mediator
Quick start for ONTAP Mediator
Contributors netapp-aoife netapp-camdenc
To get started with ONTAP Mediator, you install the software and configure it to work with your ONTAP environment.
One Install ONTAP Mediator
Install ONTAP Mediator on your system and ensure that all required dependencies are met.
Two Verify the ONTAP Mediator installation
Verify that the ONTAP Mediator installation was successful by checking the service status and reviewing the logs for any errors or warnings.
Three Configure ONTAP Mediator for your ONTAP environment
Depending on whether you want to use ONTAP Mediator for MetroCluster IP, SnapMirror active sync, or both, follow the appropriate configuration steps to ensure that all necessary settings are correctly applied.
What's next?
You can now use ONTAP Mediator to monitor MetroCluster IP configurations, SnapMirror active sync configurations, or both. For more information, refer to the SnapMirror active sync documentation and MetroCluster documentation.
