ONTAP performance counter mapping
headroom_aggregate
Display message service time variance and message inter-arrival time variance for aggregates in a node.
Classic Object: resource_headroom_aggr
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}:{instance_uuid}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
System node name
instance_name
name
This is the name of the headroom_aggregate row.
instance_uuid
uuid
This is the unique identifier for the headroom_aggregate row.
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
service_time
service_time
Disk aggregate service time variance statistics.
interarrival_time
inter_arrival_time
Disk aggregate inter-arrival time variance statistics.
current_utilization
current_utilization
This is the storage aggregate average utilization of all the data disks in the
aggregate.
current_utilization_total
current_utilization_denominator
This is the denominator value used to compute current utilization.
current_ops
current_ops
Total number of I/Os processed by the aggregate per second.
current_latency
current_latency
This is the storage aggregate average latency per message at the disk level.
optimal_point_utilization
optimal_point.utilization
The utilization component of the optimal point of the latency/utilization curve.
optimal_point_latency
optimal_point.latency
The latency component of the optimal point of the latency/utilization curve.
optimal_point_ops
optimal_point.ops
The ops component of the optimal point derived from the latency/utilzation
curve.
optimal_point_confidence_factor
optimal_point.confidence_factor
The confidence factor for the optimal point value based on the observed resource
latency and utilization.
optimal_point_samples
optimal_point.samples
The base counter for optimal_point_utilization, optimal_point_latency,
optimal_point_confidence_factor, and optimal_point_ops. This is the number of
one-minute samples since bootup.
ewma_hourly
ewma.hourly
Hourly exponential weighted moving average.
ewm_std_dev_hourly
ewm_std_dev.hourly
Hourly exponential weighted moving standard deviation based on one-minute
average values.
ewma_daily
ewma.daily
Daily exponential weighted moving average.
ewm_std_dev_daily
ewm_std_dev.daily
Daily exponential weighted moving standard deviation based on one-minute average
values.
ewma_weekly
ewma.weekly
Weekly exponential weighted moving average.
ewm_std_dev_weekly
ewm_std_dev.weekly
Weekly exponential weighted moving standard deviation based on one-minute
average values.
ewma_monthly
ewma.monthly
Monthly exponential weighted moving average.
ewm_std_dev_monthly
ewm_std_dev.monthly
Monthly exponential weighted moving standard deviation based on one-minute
average values.
current_driver_qtime
current_driver_queue_time
This is the disk driver average queue time for the storage aggregate.
observations_skipped
The number of observations not processed.
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
uuid
This counter now returns only the storage aggregate UUID instead of
a combination of the aggregate name and aggregate UUID.
Table Aliases
This section describes aliases for aggregated tables.
