headroom_aggregate
Display message service time variance and message inter-arrival time variance for aggregates in a node.
Classic Object: resource_headroom_aggr
Table Row IDs
| ID Format | Aggregation Type | Comment |
{instance_name}:{instance_uuid} |
(not applicable) |
This represents the construction of the row ID field, which is a single unique string that identifies a row. |
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
| Classic String Counter | REST Property | Description |
node_name |
node.name |
System node name |
instance_name |
name |
This is the name of the headroom_aggregate row. |
instance_uuid |
uuid |
This is the unique identifier for the headroom_aggregate row. |
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
| Classic Numeric Counter | REST Counter | Description |
service_time |
service_time |
Disk aggregate service time variance statistics. |
interarrival_time |
inter_arrival_time |
Disk aggregate inter-arrival time variance statistics. |
current_utilization |
This is the storage aggregate average utilization of all the data disks in the |
current_utilization_total |
current_utilization_denominator |
This is the denominator value used to compute current utilization. |
current_ops |
current_ops |
Total number of I/Os processed by the aggregate per second. |
current_latency |
current_latency |
This is the storage aggregate average latency per message at the disk level. |
optimal_point_utilization |
optimal_point.utilization |
The utilization component of the optimal point of the latency/utilization curve. |
optimal_point_latency |
optimal_point.latency |
The latency component of the optimal point of the latency/utilization curve. |
optimal_point_ops |
optimal_point.ops |
The ops component of the optimal point derived from the latency/utilzation |
optimal_point_confidence_factor |
optimal_point.confidence_factor |
The confidence factor for the optimal point value based on the observed resource |
optimal_point_samples |
optimal_point.samples |
The base counter for optimal_point_utilization, optimal_point_latency, |
ewma_hourly |
ewma.hourly |
Hourly exponential weighted moving average. |
ewm_std_dev_hourly |
ewm_std_dev.hourly |
Hourly exponential weighted moving standard deviation based on one-minute |
ewma_daily |
ewma.daily |
Daily exponential weighted moving average. |
ewm_std_dev_daily |
ewm_std_dev.daily |
Daily exponential weighted moving standard deviation based on one-minute average |
ewma_weekly |
ewma.weekly |
Weekly exponential weighted moving average. |
ewm_std_dev_weekly |
ewm_std_dev.weekly |
Weekly exponential weighted moving standard deviation based on one-minute |
ewma_monthly |
ewma.monthly |
Monthly exponential weighted moving average. |
ewm_std_dev_monthly |
ewm_std_dev.monthly |
Monthly exponential weighted moving standard deviation based on one-minute |
current_driver_qtime |
current_driver_queue_time |
This is the disk driver average queue time for the storage aggregate. |
observations_skipped |
The number of observations not processed. |
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
uuid |
This counter now returns only the storage aggregate UUID instead of |
Table Aliases
This section describes aliases for aggregated tables.
