ONTAP REST API cluster endpoints
Cluster endpoints support a variety of workflows such as creating the cluster, adding nodes, and managing configuration data for both clusters and nodes. Utilize these APIs to discover and integrate nodes, handle job updates, and upgrade cluster software efficiently. Certain endpoints are accessible even before cluster creation, aiding in setup and monitoring tasks.
Overview
These APIs enable you to perform a number of independent workflows, including:
Creating the cluster
Adding nodes to the cluster
Managing cluster configuration data (including name, version, NTP servers, name servers, and DNS domains)
Managing node configuration data (including node names, models, serial numbers, and HA group information)
Discovering the nodes on the cluster network that can be added to the cluster
Viewing and updating current and recent jobs
Updating the cluster software
Pre-Cluster APIs
A few of the cluster APIs (namely, POST/OPTIONS on /api/cluster, GET/HEAD/OPTIONS on /api/cluster/nodes, and calls on /api/cluster/jobs) are allowed before the cluster is created. These APIs support creation of the cluster and monitoring of its progress. Any other cluster API used before the cluster is created will fail.
