ONTAP REST API cluster endpoints
Manage your ONTAP cluster with APIs for creating the cluster, adding nodes, and configuring cluster and node settings. Use these endpoints to monitor jobs and update software, with certain APIs available even before the cluster is fully created.
Overview
These APIs enable you to perform a number of independent workflows, including:
Creating the cluster
Adding nodes to the cluster
Managing cluster configuration data (including name, version, NTP servers, name servers, and DNS domains)
Managing node configuration data (including node names, models, serial numbers, and HA group information)
Discovering the nodes on the cluster network that can be added to the cluster
Viewing and updating current and recent jobs
Updating the cluster software
Pre-Cluster APIs
A few of the cluster APIs (namely, POST/OPTIONS on /api/cluster, GET/HEAD/OPTIONS on /api/cluster/nodes, and calls on /api/cluster/jobs) are allowed before the cluster is created. These APIs support creation of the cluster and monitoring of its progress. Any other cluster API used before the cluster is created will fail.
