REST API reference
ONTAP REST API cluster endpoints
Manage cluster creation, configuration, nodes, and software updates using these endpoints to streamline and oversee your ONTAP cluster operations. Utilize pre-cluster APIs to initiate cluster formation and track its progress efficiently.
Overview
These APIs enable you to perform a number of independent workflows, including:
  • Creating the cluster
  • Adding nodes to the cluster
  • Managing cluster configuration data (including name, version, NTP servers, name servers, and DNS domains)
  • Managing node configuration data (including node names, models, serial numbers, and HA group information)
  • Discovering the nodes on the cluster network that can be added to the cluster
  • Viewing and updating current and recent jobs
  • Updating the cluster software
Pre-Cluster APIs
A few of the cluster APIs (namely, POST/OPTIONS on /api/cluster, GET/HEAD/OPTIONS on /api/cluster/nodes, and calls on /api/cluster/jobs) are allowed before the cluster is created. These APIs support creation of the cluster and monitoring of its progress. Any other cluster API used before the cluster is created will fail.
