REST API reference
Delete an ONTAP Mediator
Removes an ONTAP mediator, eliminating its configuration and presence from the system.
HTTP method and endpoint
DELETE /cluster/mediators/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Deletes the mediator.
uuid
string
path
True
  • format: uuid
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
ca_certificate
string
CA certificate for ONTAP Mediator. This is optional if the certificate is already installed.
  • x-ntap-createOnly: true
  • Introduced in: 9.8
dr_group
dr_group
DR group reference.
ip_address
string
The IP address of the mediator.
password
string
The password used to connect to the REST server on the mediator.
peer_cluster
peer_cluster
The peer cluster that the mediator service is used for.
peer_mediator_connectivity
string
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown.
port
integer
The REST server's port number on the mediator.
reachable
boolean
Indicates the connectivity status of the mediator.
user
string
The username used to connect to the REST server on the mediator.
uuid
string
The unique identifier for the mediator service.
Example request
  "ca_certificate": "string",
  "dr_group": {
    "id": 0
  "ip_address": "10.10.10.7",
  "password": "mypassword",
  "peer_cluster": {
        "href": "/api/resourcelink"
    "name": "cluster2",
    "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
  "peer_mediator_connectivity": "connected",
  "port": 31784,
  "reachable": 1,
  "user": "myusername",
  "uuid": "string"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: Default
ONTAP Error Response codes
Error code Description
13369377
Mediator field "mediator.id" does not exist.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
dr_group
DR group reference.
id
integer
DR Group ID
string
self
peer_cluster
_links
_links
name
string
uuid
string
mediator
Mediator information
ca_certificate
string
dr_group
dr_group
DR group reference.
ip_address
string
password
string
peer_cluster
peer_cluster
string
port
integer
reachable
boolean
user
string
uuid
string
_links
_links
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
