Delete an ONTAP Mediator
Removes the specified mediator, typically used when you need to decommission or replace a mediator in your storage environment.
HTTP method and endpoint
DELETE /cluster/mediators/{uuid}
Introduced in
ONTAP 9.8
Usage notes
Deletes the mediator.
uuid |
string |
path |
True |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
account_token |
string |
NetApp Console account token. This field is only applicable to the ONTAP cloud mediator.
bluexp_account_token |
string |
BlueXP account token. This field is only applicable to the ONTAP cloud mediator. This has been replaced by account_token. Support for this field will be removed in a future release.
bluexp_org_id |
string |
BlueXP organization ID. This field is only applicable to the ONTAP cloud mediator. This has been replaced by org_id. Support for this field will be removed in a future release.
ca_certificate |
string |
CA certificate for ONTAP Mediator. This is optional if the certificate is already installed.
connection_type |
string |
Connection type from ONTAP MetroCluster to mediator. Applicable only to on-prem mediator used in ONTAP MetroCluster configurations.
dr_group |
DR group reference. |
ip_address |
string |
The IP address of the mediator. |
local_mediator_connectivity |
string |
Indicates the mediator connectivity status of the local cluster. Possible values are connected, unreachable, unusable and down-high-latency. This field is only applicable to the mediators in SnapMirror active sync configuration. |
org_id |
string |
NetApp Console organization ID. This field is only applicable to the ONTAP cloud mediator.
password |
string |
The password used to connect to the REST server on the mediator. |
peer_cluster |
The peer cluster that the mediator service is used for. |
peer_mediator_connectivity |
string |
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown and down-high-latency. |
port |
integer |
The REST server's port number on the mediator. |
reachable |
boolean |
Indicates the connectivity status of the mediator. |
service_account_client_id |
string |
Client ID of the NetApp Console service account. This field is only applicable to the ONTAP cloud mediator.
service_account_client_secret |
string |
Client secret token of the NetApp Console service account. This field is only applicable to the ONTAP cloud mediator.
strict_cert_validation |
boolean |
Indicates if strict validation of certificates is performed while making REST API calls to the mediator. This field is only applicable to the ONTAP Cloud Mediator.
type |
string |
Mediator type. This field is only applicable to the mediators in SnapMirror active sync configuration. |
use_http_proxy_local |
boolean |
Indicates if the local cluster should use an http-proxy server while making REST API calls to the mediator. This field is only applicable to the ONTAP cloud mediator.
use_http_proxy_remote |
boolean |
Indicates if the remote cluster should use an http-proxy server while making REST API calls to the mediator. This field is only applicable to the ONTAP cloud mediator.
user |
string |
The username used to connect to the REST server on the mediator. |
uuid |
string |
The unique identifier for the mediator service. |
Example request
"account_token": "string",
"bluexp_account_token": "string",
"bluexp_org_id": "string",
"ca_certificate": "string",
"connection_type": "string",
"dr_group": {
"id": 0
"ip_address": "10.10.10.7",
"local_mediator_connectivity": "connected",
"org_id": "string",
"password": "mypassword",
"peer_cluster": {
"href": "/api/resourcelink"
"name": "cluster2",
"uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
"peer_mediator_connectivity": "connected",
"port": 31784,
"reachable": 1,
"service_account_client_id": "string",
"service_account_client_secret": "string",
"strict_cert_validation": 1,
"type": "string",
"use_http_proxy_local": 1,
"use_http_proxy_remote": 1,
"user": "myusername",
"uuid": "string"
Status: 200, Ok
job |
"job": {
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response codes
| Error code | Description |
13369377 |
Mediator field "mediator.id" does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
dr_group
DR group reference.
id |
integer |
DR Group ID |
href |
string |
_links
self |
peer_cluster
_links |
name |
string |
uuid |
string |
mediator
Mediator information
account_token |
string |
string |
bluexp_org_id |
string |
ca_certificate |
string |
connection_type |
string |
dr_group |
ip_address |
string |
string |
org_id |
string |
password |
string |
peer_cluster |
string |
port |
integer |
reachable |
boolean |
string |
string |
boolean |
type |
string |
boolean |
boolean |
user |
string |
uuid |
string |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
