Delete an ONTAP Mediator
Deletes a mediator to remove it from the ONTAP environment when it is no longer needed.
HTTP method and endpoint
DELETE /cluster/mediators/{uuid}
Introduced in
ONTAP 9.8
uuid |
string |
path |
True |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
ca_certificate |
string |
CA certificate for ONTAP Mediator. This is optional if the certificate is already installed.
dr_group |
DR group reference. |
ip_address |
string |
The IP address of the mediator. |
password |
string |
The password used to connect to the REST server on the mediator. |
peer_cluster |
The peer cluster that the mediator service is used for. |
peer_mediator_connectivity |
string |
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown. |
port |
integer |
The REST server's port number on the mediator. |
reachable |
boolean |
Indicates the connectivity status of the mediator. |
user |
string |
The username used to connect to the REST server on the mediator. |
uuid |
string |
The unique identifier for the mediator service. |
Example request
"ca_certificate": "string",
"dr_group": {
"id": 0
"ip_address": "10.10.10.7",
"password": "mypassword",
"peer_cluster": {
"href": "/api/resourcelink"
"name": "cluster2",
"uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
"peer_mediator_connectivity": "connected",
"port": 31784,
"reachable": 1,
"user": "myusername",
"uuid": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response codes
| Error code | Description |
13369377 |
Mediator field "mediator.id" does not exist. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
dr_group
DR group reference.
id |
integer |
DR Group ID |
href |
string |
_links
self |
peer_cluster
_links |
name |
string |
uuid |
string |
mediator
Mediator information
ca_certificate |
string |
dr_group |
ip_address |
string |
password |
string |
peer_cluster |
string |
port |
integer |
reachable |
boolean |
user |
string |
uuid |
string |
job_link
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
