REST API reference
Delete a cluster peer
Deletes a cluster peer to remove its configuration and end its communication with other clusters.
HTTP method and endpoint
DELETE /cluster/peers/{uuid}
Introduced in
ONTAP 9.6
uuid
string
path
True
Cluster peer relationship UUID
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
4663070
Unable to delete cluster peer relationship due to an ongoing Vserver migration.
Name Type Description
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
